stalling out...
Old Jan 29, 2010 | 09:00 AM
95F250351's Avatar
95F250351
stalling out...
hey guys, hoping for some help on a quick issue. did a search, but didnt have much luck.
my 95 250 with the 351 nearly stalls out, and once did stall out when i tried to apply gas from a stand still. the rpms drop way low, then come back up when i hit the gas, and once the truck just died.
what would cause the engine to choke like that when i add gas?
just did the plugs...
thanks in advance
Old Jan 29, 2010 | 09:17 AM
subford's Avatar
subford
Sounds like a bad IAC valve and maybe a bad TPS also.
While it is idling pull the plug on the IAC valve and see if the engine dies.
If it does not die the IAC is bad.
If both the IAC and TPS are good after checking them you might take it to some shop and have them clean the injectors.
