CC844 Springs w/dual Shocks
I'm interested, I hadn't considered if the dual shocks would affect anything before.
If you want some good info on these springs, check out:
https://www.ford-trucks.com/forums/9...0-springs.html
I know that the spring may or may not hit against the ball joint nut. This seems to be the major issue.
https://www.ford-trucks.com/forums/8...g-problem.html
Macintyremustang had an issue and he was installing them on a truck with quad shocks. His issue was no due to the shocks though. The springs clear the the shocks just fine. Some people have issues with aligning the truck afterwards as the coil touches the camber adjusting nut. A quality alignment shop will have no problems however. Mine touched and was aligned easily. The issue seems to be brand related. The moogs are a little bit different than the spicers.
PRIMERED79 SHORT BED
12-28-2015 03:25 PM
juddspaintballs
03-19-2015 07:24 AM
twincam00
12-09-2012 04:51 PM
xc4jokestomper
06-11-2011 01:47 PM
macintyremustang
10-23-2008 02:57 PM
