04 nav suspension busted
Old Jan 28, 2010 | 06:05 PM
Reid lariat's Avatar
Reid lariat
The right side of my wifes nav does not inflate. I was wondering if there was a way to release the pressure in the left side to even it out and then I would turn the system off. Any thoughts or suggestions would be appreciated.
Old Jan 28, 2010 | 06:44 PM
alloro's Avatar
alloro
Wouldn't turning the suspension system switch or even just the ignition switch to off cause the suspension to deflate?
Old Jan 28, 2010 | 07:45 PM
Reid lariat
I was hoping it would but that was not the case. Left side is up and right stays down no matter what I do.
Old Jan 28, 2010 | 08:56 PM
alloro's Avatar
alloro
Did you check for blown fuses?
Old Jan 28, 2010 | 09:15 PM
fordtech08's Avatar
fordtech08
check the height sensors in the front good chance one arm came off
your better off fixing it then driving with out air it will ruin the system
Old Jan 29, 2010 | 04:45 AM
Reid lariat
Where do I find the height sensors? I here the compressor and it is louder than it used to be, I also here air being released very loudly so I assumed it was either the compressor or an air hose problem.
Old Jan 29, 2010 | 08:07 AM
fordtech08's Avatar
fordtech08
you'll find the front height sensors behind each wheel, but since you hear an air leak that is most likely the cause
