Sponsored by: Real Truck
trans temp gauge
Old Jan 28, 2010 | 12:21 PM
F-250beast's Avatar
F-250beast
trans temp gauge
i have a 99 F-250 with v10 im looking at putting a trans temp gauge on were do the sender unit go in at on the tranny. you have to tap a new hole or what.
Old Jan 28, 2010 | 12:37 PM
superduty4x4's Avatar
superduty4x4
There is a bolt on the drivers side of the trans in front of the big black electrical connector just above the pan. Pull it out and put your temp sender in there. Or drill and tap the pan if you really want to.
Old Jan 28, 2010 | 04:07 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
X2 for above! Works great
Old Jan 28, 2010 | 04:14 PM
Monster-4's Avatar
Monster-4
Or buy a ScanGauge.
Old Jan 28, 2010 | 06:30 PM
1975StroppeBaja's Avatar
1975StroppeBaja
x3, that's where mine is....
Old Jan 28, 2010 | 06:37 PM
Jigger2020's Avatar
Jigger2020
if your instruction's say to put it in the pan then put it in the pan so the probe is in trans fluid,Gigger
Old Jan 28, 2010 | 07:19 PM
1975StroppeBaja
It doesn't need to go in the pan. Sure, that would work fine but its unnecessary. The sender will be in constant contact with trans fluid in the test port and its already the right thread size (for most senders). Its a no brainer really.
Old Jan 28, 2010 | 07:28 PM
Jigger2020's Avatar
Jigger2020
F250 Beast can do what ever he wants to but when he drop's the pan to put the sending unit in he can service the filter & fluid too,bonus...Gigger
