CLUTCH
Old Jan 28, 2010 | 09:58 AM
75Three90's Avatar
75Three90
CLUTCH
Ok I just bought this 1990 ford 4x4 short wheel base pick up it has 31in a/t's with a 3in lift but the clutch needs ajusting how do i do that. a buddy said u do it from the slave cyl.
Old Jan 28, 2010 | 12:17 PM
Lazy K's Avatar
Lazy K
The clutch is hydraulic and is self adjusting. If you are having problems with clutch disengagement check the bushes in the pedal linkage and check the firewall for cracking/flexing.
Old Jan 28, 2010 | 01:04 PM
75Three90's Avatar
75Three90
well the problem is the clutch is either not fully engaging or putting to much pressure on the pressure plate, somone else said adjust the master cyl.
Old Jan 28, 2010 | 01:14 PM
andym's Avatar
andym
Let's be clear: You CANNOT adjust the hydraulic clutch on your truck!
Is the clutch slipping? How many miles are on it?
Old Jan 28, 2010 | 02:18 PM
75Three90's Avatar
75Three90
the clutch aint slippin its not fully engaging
Old Jan 28, 2010 | 02:35 PM
andym's Avatar
andym
This is not possible. If the clutch is not fully engaging it WILL slip. That's how clutches work.
Maybe you should start over and tell us about the vehicle and describe the problem it's having in detail.
Old Jan 29, 2010 | 11:38 AM
75Three90's Avatar
75Three90
alright, when i bought the truck the pedal was really hard and now between shifts i still have power, i still have speed but it smokes when im slowing down, my buddys did the same thing when he put his new clutch in he unhooked the pedal from the master cyl and adjusted it and its been fine ever since but since he doesnt have time to help me i was trying to find somone else that knew how to do it
Old Jan 29, 2010 | 11:40 AM
andym's Avatar
andym
What year is your truck? It sounds like your clutch isn't disengaging. Go back to post #2 and check those things out.
Old Jan 29, 2010 | 12:16 PM
Lazy K's Avatar
Lazy K
Hydraulic Clutch Troubleshooting .: Articles Have a read through this. Also check for firewall cracking/flexing.
Old Jan 29, 2010 | 04:52 PM
EPNCSU2006's Avatar
EPNCSU2006
You can press a new lever on the cross-shaft that connects the pedal to the master cylinder, but that's a set-it-once-and-be-done-with-it adjustment. It's not something that will move over time. If the clutch pedal comes (or can be pulled) all the way up to the stop, the pedal is adjusted properly.
Old Feb 11, 2010 | 02:42 PM
75Three90's Avatar
75Three90
i know that now thanks, we tryed that
Cabledude
Oct 28, 2014 10:16 PM
patsfan0123
1983 - 2012 Ranger & B-Series
Nov 19, 2009 12:28 AM
Lumpy250
Jul 5, 2006 01:24 AM
boogity24
Apr 11, 2004 12:06 AM
tranthac1
Apr 4, 2003 06:10 AM
