Radiator questions/repair
Old Jan 27, 2010 | 09:40 PM
Silver_Blaze's Avatar
Silver_Blaze
Exclamation Radiator questions/repair
Yup, I'm back again. >.< Dang truck!!
Anyway, Jasper (1985 Ford F-150 2WD 5.8 L V8) has had some form of an antifreeze leak for awhile now. When the engine gets hot, you can smell that burnt marshmallow scent.
Well, I leave work today, and there's a BIG puddle under the front of it. -_- So I drive him home (5 minute drive, seriously), pull in, park, turn off, and get out. And already there's a half-dollar size puddle. I pop the hood, and the entire reservoir is empty, and the fender is full of antifreeze. I don't see where it's leaking from, since everything is wet. It's dripping pretty solidly though, and he blew a radiator plug a few months back.
So, should I just replace all the hoses and hope the radiator is solid, or should I just replace the entire darn thing? Also...the one in there now is plastic, and everything I'm finding online is now showing brass and aluminum. Why?
Thanks again so much guys!!
Old Jan 27, 2010 | 09:45 PM
ctubutis's Avatar
ctubutis
Do the radiator hoses get soft & mushy? If so, replace them, you'll hopefully locate a
heater hose that exploded or sumthin'. You can maybe rent a pressure tester - basically,
a device that fits where the radiator cap goes - with a plunger that you pump up to
pressurize the system - and then locate the leak(s) for certain.
Old Jan 27, 2010 | 09:54 PM
Silver_Blaze
Even when the antifreeze is drained out, the hoses are rock hard, and really REALLY hard to move. I had to take the radiator out to replace the petcock valve, and they stayed like, perfectly in place. With the pressure tester...I don't need to have the engine on? If so, that'd be perfect! Something to get after work tomorrow!
Old Jan 27, 2010 | 10:15 PM
ctubutis's Avatar
ctubutis
No, you don't.
Could also be your water pump leaking (bearing is worn out) and antifreeze is
getting sprayed around by the fan.
Old Jan 28, 2010 | 07:10 AM
Silver_Blaze
No, you don't.
.....never thought of that!! Thanks again!!
Hopefully I'll have some news tonight. -_- This is just...yeah. Nother Day, Nother 100 bucks.
