EBPV Cleaning and Switched
Old Jan 27, 2010 | 09:30 PM
BVMS's Avatar
BVMS
Unhappy EBPV Cleaning and Switched
Anyone have a simple wright up on how to just wire it in to a toggle switch? And I've also heard you need to clean it? It's a 94.5 Powerstroke. Thanks guys
Old Jan 27, 2010 | 09:35 PM
Talyn's Avatar
Talyn
I've never heard the cleaning part. but the switch part is easy. I dont remember off hand how to do it though.
Old Jan 27, 2010 | 09:36 PM
BVMS's Avatar
BVMS
Sweet read somewhere that it needed to be cleaned
Old Jan 28, 2010 | 07:55 AM
Red97350's Avatar
Red97350
A friend of mine met a guy that actually had a 3 way switch on his ebpv. If I believe correctly, it was always open, operating normally and closed when you applied the brakes. I was thinking about doing it on my truck, but haven't done the research. I think if you do a search on google, you should be able to find a write-up on it.
Red
Old Jan 28, 2010 | 09:39 AM
Talyn's Avatar
Talyn
Having it work with the brakes isn't necessarily good.
That sucker could stick closed, then your screwed.
If I were to wire a 3 way switch into it, I would wire for. Open, closed, Normal Operation.
I just want mine for start-up to help clear up some of my smoke and warmup time.
