Weird no start problem...HELP!!
Old Jan 28, 2010 | 05:51 PM
fmc400's Avatar
fmc400
MSEE
If the light is blinking, then the module is firing the coil. That means the distributor, pickup module, and associated wiring is in working order. This is a good thing.
Pull off the distributor cap and look at the contacts underneath, and inspect the rotor.
Old Jan 28, 2010 | 06:42 PM
Thomsen's Avatar
Thomsen
Ok thanks fmc. I will take a look at it again tomorrow when I have time...
Old Jan 29, 2010 | 01:05 PM
Thomsen's Avatar
Thomsen
The contacts look good. The rotor also looks to be in good shape...What now?
Old Jan 29, 2010 | 05:10 PM
oltrucker's Avatar
oltrucker
the best thing i e3ver did was to drop a ma;llory unalite distributer in my 77 and recycle the ford ingnition,,,,,no more burnt modules etc.
Old Jan 29, 2010 | 05:19 PM
Furyus1's Avatar
Furyus1
Just a thought, but since the coil appears to be firing - could it be possible the distributor lock-down came loose and the distributor rotated enough to throw the timing off and cause it not start?
Old Jan 29, 2010 | 06:25 PM
77h0t_r0d_wrecker's Avatar
77h0t_r0d_wrecker
Or timing skipped a tooth or two.
Are you definitely not getting spark at the plug? Did you take a peek in the carb and move the throttle to see if fuel is getting in there?
Old Jan 29, 2010 | 06:57 PM
NBC-Steve's Avatar
NBC-Steve
It looks like FMC400 is giving you some excellent suggestions on troubleshooting your ignition system but I would like to offer up a quick test for spark. Disconnect one of the spark plug wires and place it on the end of a screwdriver and hold it next to ground so that the screwdriver shaft and ground is about a millimeter apart. Have some one crank over the engine. If you see (Or feel) spark you will know at least you're firing. Next test your timing and fuel.
Good Luck!
Old Jan 30, 2010 | 01:00 AM
Thomsen's Avatar
Thomsen
The day that it did this it was running great...no problems at all. I shut the truck off and went inside the house for awhile, came back out and it would not even attempt to start. The dizzy hold down is tight and I checked to make sure that the rotor is turning when the enging is cranking. Any thoughts?
Old Jan 30, 2010 | 01:39 PM
fmc400's Avatar
fmc400
MSEE
Great suggestion NBC-Steve. This would be another good test, to make sure the spark is actually getting to the plugs. After that, I'd move on to fuel - what specifically have you done to check that it's getting fuel?
Old Jan 31, 2010 | 05:36 PM
Thomsen's Avatar
Thomsen
I looked in the carb and made sure it was spraying out....I will check tomorrow if I have spark at the plugs tomorrow. Thanks guys.
Old Feb 18, 2010 | 12:44 PM
Thomsen's Avatar
Thomsen
I had a buddy help and I have confirmed that the spark plugs are NOT getting spark. I am getting fuel. So what now? Distributor I assume?
Old Feb 18, 2010 | 07:06 PM
Thomsen's Avatar
Thomsen
So what do you guys think?Anyone?
Old Feb 19, 2010 | 12:31 AM
  #28
maskedman's Avatar
maskedman
I would try checking the resistance of your coil wire.The resistance should not exceed 5000 ohms per foot.Also check the resistance of the coil wire through the contact in the distibutor cap.You haven't mentioned this, but test the resistance of the wiring to the magnetic pickup in the distibutor.This test is more accurate when the engine is at operating temperature but might show something none the less.Pull the connection apart at the distibutor and measure the resistance between the orange and purple wires.This reading should be between 400 and 800 ohms.Then connect your multimeter between the orange wire and ground,and then do the same with the purple wire.These readings should be at least 70,000 ohms or more.If any of the readings vary in the test,the probable culprit is the magnetic pickup or stator if you will.Also check the ground wire and ground screw inside the distibutor for an open.Look very close at the cap and rotor once again something is interrupting the secondary voltage from the ignition.Post back and let us know what you find.
Old Feb 19, 2010 | 05:12 AM
  #29
Jermafenser's Avatar
Jermafenser
Pickup coil? Stator?
Old Feb 19, 2010 | 11:54 AM
  #30
montana_highboy's Avatar
montana_highboy
Originally Posted by maskedman
You haven't mentioned this, but test the resistance of the wiring to the magnetic pickup in the distibutor. Pull the connection apart at the distibutor and measure the resistance between the orange and purple wires.This reading should be between 400 and 800 ohms.
Way back in post #15 i too recommended the OP test the pickup, not sure if he ever did or not...
