bad vibes
Old Jan 27, 2010 | 08:28 AM
91redford's Avatar
91redford
bad vibes
my trusty '91 f150 started acting a little weird yesterday...it has approx 90xxx on a 300 6 with a manual 5 speed tranny, i have had the driveline out for u joint replacement last year, so i checked the bolts on both ends of it for any that had come loose, it started with a slight sensation of vibration in 4th around 15oo RPM, now after a few hundred more miles it's becoming worse, in 3rd below 2000 RPM it can be felt/heard through the stearing wheel...whataya think guys? broken motor mount? clutch issues? shifts fine. help! j
Old Jan 27, 2010 | 08:33 AM
carverfordan's Avatar
carverfordan
Make sure the U-joint caps are positioned in the yoke properly even if tight they will not be centered , had that problem once, and created an very annoying vib. is their a carrier bearing between trans. and rear end is it good? front wheel bearing or rear.
