help identify this part?
Old Jan 26, 2010 | 07:32 PM
Spydycarnge's Avatar
Spydycarnge
I have a 1982 F250 with a 302 automatic trans. 2 wd. and aftermarket cruise control. This part is near the firewall on the top of the motor it is black with a wire that comes out of it and then connects to what looks like a pull chain from a lamp and is attached to the carb throttle arm. When I manually accelerate the throttle it causes slack in the wire(pull chain) what is this part andwhat does it do?
Old Jan 26, 2010 | 07:34 PM
Archion's Avatar
Archion
Veteran: Marine Corps
That would be the cruise control servo. When you activate the cruise, it pulls the throttle.
