General Automotive Discussion
need help! 00 chevy blazer
Old Jan 26, 2010 | 04:52 PM
dougbrown's Avatar
dougbrown
I have a friends blazer that has a driver side door problem. It will not stay lacthed and doesn't shut right. It is tied shut with a rope to the roof rack. I don't know how big of a job this will be and don't want to get in over my head. Does anyone have a blazer around that year that could send me pics of the driver side door hinges?
Also what are the cross years.
I'm going to call around to a few junk yard to see if they have one.
Any info before I comit to doing this would be good. Going to look at it friday.
Old Jan 26, 2010 | 06:12 PM
Phinxter's Avatar
Phinxter
generally the hinge pins wear out and cause it to sag, there are parts available to fix this. I'm not sure why you would replace the whole door. I did a 2 second google search and found this
How to Fix Chevy S-10 Door Hinges | eHow.com
Old Jan 26, 2010 | 06:25 PM
dougbrown's Avatar
dougbrown
I'm looking at replacing the hinges and latch system not hole door.
Old Apr 10, 2010 | 02:33 AM
Skip1970's Avatar
Skip1970
the s10 hinges are welded onto the body
Old Apr 10, 2010 | 08:53 PM
LCAM-01XA's Avatar
LCAM-01XA
Yes they are, but the hinge pins ain't - as long as they didn't wear into the hinge brackets just replacing the pins and the bushings will be enough to fix the sagging door.
CraigerF100
112
Feb 3, 2017 06:20 PM
norman2012
Dec 31, 2016 07:41 PM
91blaze
1947 and Older Ford Trucks
46
Nov 6, 2013 08:25 PM
rockstate45
1978 - 1996 Big Bronco
36
Dec 23, 2009 02:18 PM
RyanGruhn
27
Aug 25, 2008 03:28 PM
