Installing 9" rearend
Old Jan 25, 2010 | 10:57 AM
Pappys53's Avatar
Pappys53
I will be installing my 9" rear end this spring. I have a 350 with 350turbo tranny, will I need to do anything different with the drive shaft?
Old Jan 25, 2010 | 11:10 AM
fergusonicford's Avatar
fergusonicford
yes; Length change and Universal Joint change. Check for length with vehicle on the ground; not up on jackstands. Be sure to have it Balanced.
Old Jan 25, 2010 | 11:11 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Possibly, the two areas to look at would be the "U" joint and the length of the snout of the 9" as comparer to the original. I'm betting there isn't much difference between the snout lengths so its probably not an issue. If there is more than about an inch difference then it might be a problem and the driveshaft would have to be shortened a bit.
There is a chance the the "U" joint cross shaft dimensions will be different, if so you have several choices. The easiest is to buy a "U" joint with an offset cross. If you have to have the driveshaft cut down then it would be easy to add the correct size rear yoke. Or you can change the yoke out on the 9".
The place to start is to grab a tape measure and measure your "U" joint on your truck and the yoke on the 9"
Good luck
Bobby
Philip Holwell
13
Jan 28, 2013 08:52 PM
1Aauto
Dec 14, 2012 04:12 AM
IDIDieselJohn
May 12, 2009 04:02 PM
frankenstein
30
Mar 11, 2006 08:20 PM
BrentKasson
Nov 17, 2004 08:32 PM
