engine identification
Old Jan 24, 2010 | 06:33 PM
1977fordf250's Avatar
1977fordf250
I have a motor I am trying to identify. It is out of a 1974 F250 camper special 2wd. From the best I can tell the numbers casted in the block are c7 o1f? I found them looking at the motor on the right side front. On the same side on the back of the motor I found oJ1 96087 stamped in the block. The head number is a c5aeh. I know the codes somewhat about date identification, but how do I identify the block to what it is. Also the valve covers are a 5 bolt round cover. Thanks
Old Jan 24, 2010 | 08:46 PM
bewford's Avatar
bewford
i think that head casting number is a 390, but it could be a 360 also, someone esle should be along to confirm or correct this
Old Jan 24, 2010 | 09:27 PM
montana_highboy's Avatar
montana_highboy
It's an FE 360/390, most likely a 390 in camper special.
Old Jan 25, 2010 | 03:11 PM
1977fordf250
Thanks for the help. The casting numbers make no sense to me. But the books I have seem to be for the early models. Is it possible to have a ft block? Do I have to take the motor apart to determine the engine. What are some good books for identifying motors?
Old Jan 26, 2010 | 09:12 AM
Broncoholic1's Avatar
Broncoholic1
Just pull a plug out & put in a wood dowel into the cyl. measure the stroke IIRC should be over 3.75" for the 390. Sounds like a good combo. post some pict's in you intro thread.
