Front end numbers
Old Sep 17, 1999 | 07:04 PM
BenS's Avatar
BenS
Front end numbers
Old Oct 19, 1999 | 05:51 PM
phil
Guest
Posts: n/a
Front end numbers
Help! Can anyone give me some info on my front end. The tag read 4 09 D6TA AAE
668783-1 I cant seem to locate a hub or a set of lockouts, Thanks
The truck is a 77F250
Old Oct 19, 1999 | 08:51 PM
StockMan's Avatar
StockMan
Front end numbers
Phil:
I would suggest you make friends with the parts guy at the local Ford dealer. He should be able to dust off the master parts catalog or turn on the micro-fiche machine and get you all the part nos. you need. You may also be surprised to learn what parts may still be available through Ford. I hope this helps.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Oct 20, 1999 | 07:56 AM
Phillip Guidry's Avatar
Phillip Guidry
Front end numbers
If you are refering to the splined hub,they were available to parts houses under the brake parts line such a United{NAPA},EIS & Raybestos,right were the front rotors/drums were listed. Unfortunantly,due to lack of sales at the aftermarket level,I don't believe they are listed anymore,but I can tell you they were at one time!And there is always Spicer-Dana/Perfect Circle that is available to all driveline company's as well as some parts houses.You may find the lockouts through Spicer-Dana also.
Phillip
