EGR replace
Old Jan 24, 2010 | 04:08 PM
lab1133's Avatar
lab1133
EGR replace
Replacing my EGR and oil coolers. I found I have small amount of oil and coolant in the pipe going from the air filter to the turbo, it looks like it is coming from a breather tube on the drivers side valve cover. What would be the cause of this? There is no water in the oil.
Old Jan 24, 2010 | 04:37 PM
06silvercrew's Avatar
06silvercrew
Its normal, its part of the crank case vent system. Most do a CCV reroute, do a quick search, there is a ton of good info including pics on here. Im gonna do mine when it warms up some.
EDIT: Missed the part where you said coolant, are you SURE its coolant?
Old Jan 24, 2010 | 07:25 PM
lakewood's Avatar
lakewood
Dont replace the EGR, delete it
