brake upgrade???
Old Jan 26, 2010 | 08:08 PM
oreocreaming's Avatar
oreocreaming
i dont recall my 4th gear rpms, but in 5th (od) im 2000 at 70mph. my truck is all torn apart right now, installing an intercooler, getting my radiator boiled and a leak sealed, replacing all my hoses and installing new battery cables.
Old Jan 26, 2010 | 09:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If the speedo has not been recalibrated, stock 235/85-16 tires with 3.55 gears and a ZF 5 would be running 70 MPH at 2050 RPM.
However the tire size change has you running 83 MPH at that RPM and speedo indicated speed.
On the 90 model you change gears in the transmission or transfer case to correct the speedo error.
What is the trailer you are pulling?
Something is wrong if it is still nose low with the truck on 37" tires.
I have to run a 4" drop hitch with 33" tires and no air bags.
Old Jan 26, 2010 | 11:10 PM
oreocreaming
i dont go by my spedo, i go by my gps. ive got a 2 car trailer, 7k axles, its a high deck. sits about 40 inches deck to ground. 32 1/2' long. it had 4" drop axles on it, my driveway has a crazy low dip in it that the city wont let me level it off and put a water pass drain under it. i put on straight axles on it to clear. its got a 6' dove tail that drops the rear about 20" off the ground. with my 1 car trailer i run a 10" drop and it rides perfect.
Old Jan 26, 2010 | 11:12 PM
oreocreaming
ive still got great take-off power. before the turbo it still lifted and launched like a turbo.
Old Jan 26, 2010 | 11:14 PM
oreocreaming
guys sellin a hydrobooster with the master cylinder off a 01 silverado 2500hd. would that work for me?
Old Jan 26, 2010 | 11:31 PM
starmilt's Avatar
starmilt
You would want to use your master cylinder but the booster is a possiblity. I sure wouldn't say it would for sure though.
Old Jan 26, 2010 | 11:33 PM
oreocreaming
any ideas on who might be able to? before i spend that kinda money id like to know for sure....
Old Jan 27, 2010 | 08:25 AM
87crewdually's Avatar
87crewdually
Originally Posted by oreocreaming
all torn apart right now, installing an intercooler, .
Um, pics, maybe a little write up in another thread, I'm very interested in this too.
Old Jan 27, 2010 | 10:17 AM
starmilt's Avatar
starmilt
I think it MLSC that adapted a chevy one in, but I could be wrong it was awhile ago.
Old Jan 27, 2010 | 08:29 PM
Dave Sponaugle
I can't offer any help with the Chevy unit, but the Ford unit was bolt on and play.
Hydraboost bolted right up to the firewall.
Brake rod was the correct length to hook to the brake pedal.
Hoses fit like they were made for my truck.
Master cylinder bolted right on.
MSLC, if he was the one, did mention the master cylinder to hydraboost holes were the ones he had to enlongate if I remember right.
Old Jan 27, 2010 | 09:39 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
im surprised they don't make some special high pressure brake line for all this increased line pressure.kinda scary.
Old Jan 28, 2010 | 05:35 AM
LCAM-01XA's Avatar
LCAM-01XA
Yeps, and it still works great, now even better cause of the Mk7 pump mod
That's correct, the Ford master cylinder needed the holes elongated outwards cause the studs on the hydroboost are further apart than those of the vacuum booster. Also, the pedal pushrod for the hydroboost is longer than the vacuum booster part, so the hydroboost unit needs to be spaced out away from the firewall, 2" was what I ended up at IIRC. Finding an F-Superduty hydroboost is definitely the easy way to go.
Old Jan 29, 2010 | 12:08 AM
  #28
oreocreaming
i think i scored big time today. i bought a 63 scout for $200 this afternoon. a ton of **** inside it..... was going though it and BAM, found a hydroboost! not sure what its off of yet. ill check it out when i get back into town monday or tuesday. so, how do i post some pics on here?
Old Jan 29, 2010 | 12:56 AM
  #29
starmilt's Avatar
starmilt
The way I do it is through photo bucket. But nearly anybody can tell you better than I can.
Old Mar 12, 2010 | 11:50 AM
  #30
oreocreaming
3.73's and big loads with 40" tires, better get a couple boxes of U joints.
I broke enough with 235 tires behind a stock 6.9.
Now with a modded turbo 6.9 and 285 tires, driveshfts last about 2 years, U joints last about 4 months.
4.56 gears with 40" tires would be about the same as 31" tires (235/85) and 3.55 gears.
On a 90, my guess is you have either 4.10 or 3.55 gears.
Give me a speed and RPM in 4th gear and I can tell you what gears you have now.
Also has the speedo be corrected for the tire size change?
Going from the stock 31" tires to 37" tires have created an error in the speedo reading.
235/85-16 tires with 4.10 gears would run 59 MPH at 2000 RPM in 5th gear.
Running 37" tires on the same setup at the same RPM in overdrive would be 71 MPH.
Jump to 40" tires, 2000 RPM in overdrive would be just shy of 76 MPH.
Don't forget, double the braking performance will mean you have to run double the brake line pressures.
So brake lines and hoses will be under rather extreme pressure.
Driveline and brake components have to run at 128% of the stock load to be even with what it had with stock tires.
Figure 2,000 PSI brake line pressure stock, with 40" tires that has to be 2,560 PSI to be even braking force.
2275rpm, 60mph 1:1 ratio..... id love to get 4.56 hears BUT im told id need a new front carrier, so im lookin at 500 for the rear and like 1k for the front. OR, maybe get a ARB for the front, so id be up to 1900. installed of course. i have gotten into a lot but dont really care to get into installing a air locker. seems like a lot of work.
