Heater blower motor
Old Jan 23, 2010 | 08:28 AM
mechelement's Avatar
mechelement
Heater blower motor
When it's really cold outside and I start the truck, the motor won't turn on. I turned the lights on to see if they dimmed when I tried the heater and they did not. When my motor warms up and kicks out of high idle, I can turn the heater on and it functions.
I heard a moaning squealing noise from my heater motor the first time I switched it on when it was freezing cold out there. When I turned the speed up to high, it stopped the noise. On low, the motor is a bit noisy.
Is my motor going or is there an electrical component not functioning properly or both?
Old Jan 23, 2010 | 08:55 AM
fatkid89704's Avatar
fatkid89704
whe they start making noise it is a good indication they are going bad.wait till spring and change it when it gets warm.
Old Jan 23, 2010 | 09:12 AM
mechelement
I was looking at my Chilton's manual. It looks like the heater blower motor is mounted into the firewall. I'm half tempted to pull the heater motor and really clean it up, then oil it to see if that helps. No heat when you get in the truck really sucks.
Old Jan 23, 2010 | 09:58 AM
fatkid89704
yea no heat sucks not sure about cleaning and oiling the motor.i have never tried that i just replace them when they start making that sqweeling noise
Old Jan 23, 2010 | 10:18 AM
PLC7.3's Avatar
PLC7.3
They are easy to replace and very cheap....... clean out the plenum while the fan is out.
Old Jan 23, 2010 | 10:53 AM
kenpobuck's Avatar
kenpobuck
I have tried to clean and oil them before and it only help for a short time. Three bolts and a plug and it is out, so just replace it. It will make you happier in the end.
Old Jan 23, 2010 | 04:26 PM
Rick Wallace's Avatar
Rick Wallace
They are right,I had the same problem,just replace it and you will be happy and warm
Old Jan 24, 2010 | 11:36 PM
dyoungen's Avatar
dyoungen
If you go to the trouble of removing the fan and motor, you will save your self the time of doing it again. Been there and done that, do it right the first time and you won't be sorry. I oiled a fan motor on a 1977 f100 only because I would almost have to remove the dash. It only helped a couple of weeks and back to the squeeling which is the bearings going out.
Old Jan 24, 2010 | 11:44 PM
mechelement
Ok, I'll just replace it with a new one. I found a new one for $26.00
Rusty_S
28
Nov 29, 2015 07:28 PM
riattadog
Oct 12, 2014 07:58 PM
TheBestNeverRest
2009 - 2014 F150
Dec 18, 2013 03:27 PM
ZombieSlayer
1978 - 1996 Big Bronco
Dec 9, 2013 12:52 PM
biggreen4x4
51
Dec 16, 2003 01:22 PM
