I've searched for it and gone through the common mods thread but can't find it. I found a hundred places where it was mentioned and people were told to do it but I can't find anything that tells me what it is or what it does.
Picture says it all. You have to grind a little off the the top part of the quarter to get it to fit though. Good deal since ford charges around $10 for the clips that do the same thing.
Thanks guys (repped ya Mueckster), pics are worth a thousand words! I guess this is only something you do if there's a reason to be under the valve cover anyway? Or is it important enough to pull them just to do this mod?
I would do it anyhow. Read about it for awhile, then I NEEDED to do it!
Its also a good time to check the injector hold down bolts too. Do you guys remember the torque specs (i'm in la la land lately)? Somebody's gonna ask soon enough.
Shade, you'll end up doing it eventually out of need, but the need may arise when you're in the middle of nowhere and you have to limp back home, if it even runs...so, my advice is...go ahead and make plans to do the mod on your schedule, so you don't have to in the middle of the woods somewhere...
x2...that's what happened to me...
and Roland...i'm glad you took pics, i couldn't...i was so dang oily, my wife would have beat me if i touched "her" camera...lol...what did you do, clean up, take pics, and then get dirty again???...
I've never bothered worrying about the torque on the glow plugs, even on the trucks I've changed. Just tightened them up. But to answer your question, Ford says torque to 14 ft/lbs
