Mixed Injectors?
Old Jan 22, 2010 | 03:22 PM
nateairman's Avatar
nateairman
Mixed Injectors?
I am putting new orings in my truck and noticed one of the injectors on the drivers side has the code ab on it. The other three are aa. Is this wrong?
Old Jan 22, 2010 | 03:40 PM
RRranch's Avatar
RRranch
Very wrong.
I bet that side had a miss on it. AB is a split shot with a lot more cc's than the AA code injectors.
Or possibly, someone just swapped out the solenoid on that one with a junk yard one. That shouldn't hurt anything. If the whole injector is different then you really should have the right one in it.
Old Jan 22, 2010 | 04:07 PM
fuelman's Avatar
fuelman
Unfortunately there is no way to tell(that i know) w/o taken the injector apart. Did it have alittle miss when it was running at idle?
Old Jan 22, 2010 | 04:13 PM
nateairman's Avatar
nateairman
It had a little miss at idle and else where. I am not sure about the solenoid being swapped. What needs to be taken apart to make sure it is an aa?
Old Jan 22, 2010 | 05:06 PM
fuelman's Avatar
fuelman
You have to seperate the injector,and see which style plunger and barrels.The plungers are different from what i could see when i disassembled one of each. The nozzle may be different I'm honestly not sure. The power pistons are also different but you may not be able to tell that without measuring the two.The plungers on a splitshot have holes in the bottom.I believe this is to relieve initual(spelling?) pressure creating the "pilot shot" that the splits are known for.
Old Jan 22, 2010 | 05:13 PM
fuelman's Avatar
fuelman
Ebay you can usually find an AA for sale indivivdually
Old Jan 22, 2010 | 05:22 PM
Talyn's Avatar
Talyn
Jim would know how to tell for sure. I'll Email him this thread.
If the rest were AO's we could tell for sure if it was an AB or not. heh.
Old Jan 22, 2010 | 06:29 PM
nateairman's Avatar
nateairman
Just got the passenger side injectors out. They are all AA stamped on the Solenoid. So as it stands I have 6 Original AA injectors, 1 AA from the dealership and 1 with the AB stamp.
Does anyone have instruction on the disassembly of the injectors? I would like to make sure I am running 8 AA's before I put it back together. Thank you for the help!
Old Jan 22, 2010 | 07:39 PM
Talyn's Avatar
Talyn
You need tools to do it.
I posted the thread to Jim. He usually gets on in the mornings. So i'd check back tomorrow around noon.
Old Jan 22, 2010 | 09:43 PM
fuelman's Avatar
fuelman
You need a clamp that goes in the holes on the bottom of the injector,then mounting in a vice.Then a big wrench to turn off the top half. You also need a tool to retorque everything back together. Jim sells both.Some guys take a nut breaker and grind it to fit the holes for vice mounting. It's really not hard once you've done them and have the tools.Jim may have the parts to convert the AB to an AA.
Old Jan 23, 2010 | 06:56 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
What they said.
If you've gone this far you need to make that AB an AA. And there's a very high chance that the one replaced form the Dealer is junk causing the miss. Ford only sells reman injectors that already have 1/2 million miles on them, and some of their sources do a good job, some don't. MOST of the Ford Remans I get in here have not had their tolerances addressed, they just throw in new P&B and new Nozzle and send them back out.
I've had other customers with mixed injectors and the truck ran fine. Under normal fueling/driving, the flow will be very similar if there's just one AB. But I would definitely change it.
And I would NOT ever buy any injectors off eBay. That's where everyone unloads their junk.
Let me know what I can do to help.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jan 23, 2010 | 08:01 AM
Talyn's Avatar
Talyn
Jim FTW.
That message was too short.
F the stupid short message crap.
Old Jan 23, 2010 | 08:02 AM
Talyn's Avatar
Talyn
Jim FTW.
Old Jan 23, 2010 | 09:01 AM
nateairman's Avatar
nateairman
I will make a tool or mod one to take the nozzle off and retorque it to feels just right. I don't feel like putting an injector back in that is wrong and I need the truck next week. Dang hard to find bits and pieces for these trucks here in BC.
