ok so i just bought another truck..a 2000 f150, and i plan on puttin a 6 inch lift and a 3 inch body lift on it, anyone got some pics? im also wonderin what size tires thatll fit, ive heard of people fittin 40s with that setup
here is mine, got a 6" fabtech lift with 35's. i am not sure about fittin 40" tires with just 9" of lift 6+3" body but i know for fact you can do 38's.
found this truck at farmboycustoms in florida. they make the kit for the solid axle swap i am fixing to attempt. it has 44" swampers with about 16" of lift.
i had them custom made from a place by my house. they cost me about 30 bucks for both of them but they are saved in their computer so amytime they come off or start to peel i can just go get some more. the ones i have are cut from a rebel flag but they can do any design you want.
hey thanks. i wasnt sure if you had them done or just bought them on line. i got a guy by me that i can go to and he is supposed to be good. i may have to check it out.
highteck, i like how your truck sits. i wasnt sure if the 6 inch lift would make a big difference but it actually does, which is good to know cuz i wont be doing all 9 inches at one time, i ll have to work my way up to it
thanks mike, do you know whick your lift your gona get first? 6" does make alot of difference from a stock truck. i pulled beside one the other day and took a pic so you could see the hieght difference between them but i havent posted the pic yet.
ya id like to see that, and ill probably go with the 6 first and get the most expensive part out of the way.. how much is the rear lifted on yours? i looked at a few kits that only lifted the back 3.5, but i found one i think its BDS that lifts the rear 5.5 inches, its more expensive but id rather have the extra 2 inches in the back
the lift that i bought came with lift blocks for the rear. i just had to unbolt the u-bolts, add the blocks and bolt it back down. everything was included in the lift. i paid about 2,000 bucks for it. are you going to install it?
wait i see what your sayin, the blocks are about 4.5" but the truck sits pretty level. i didnt crank my torsion bars or anything either.
I bought the same lift for my truck from BDS, but i went with the full boat and got the skid plate and the new rear leaf springs. I was happy with the whole package, and now that the leaf springs have beded in the truck is pretty level now. If you call a physical dealer for BDS u will get a better deal than on the web.
