Steering squeel
Old Nov 8, 1999 | 05:04 AM
rick's Avatar
rick
Steering squeel
I have a 77 F150 2WD and have totally rebuilt the front end and the steering gear box. Now that I am cruisin' up an down the road in a straight line, I am really anxious to get rid of the squeel when I turn the wheel. It starts with a hissing, but goes to a squeel when it goes to the far ends of the turning radius. I have "heard" that this system need to be bled just like brakes, but I don't know how to do it or if that will solve the problem. Any advice will be appreciated.
Old Nov 8, 1999 | 09:04 AM
jowilker's Avatar
jowilker
Steering squeel
First make sure the fluid level is at full. Either tighten the belt or replace it. If it is tight, try spraying some WD40 on it to see if it will quiten down.
John
Old Nov 8, 1999 | 12:14 PM
Bill Martin
Guest
Posts: n/a
Steering squeel
The power steering is bled by turning the wheel lock-to-lock a couple of times. At the limits of its travel the system purges the air from the lines. You shouldn't hold the wheel at full lock for an extended period of time however.
Old Nov 8, 1999 | 12:41 PM
Phillip Guidry's Avatar
Phillip Guidry
Steering squeel
