Help! Used wrong oil.
Old Jan 21, 2010 | 04:15 PM
vinman46's Avatar
vinman46
Smile Help! Used wrong oil.
I put Quaker State 10w-30 made for gas engines into motor. It`s my wifes truck and she had only driven 44mi. She said it started and ran fine. I got home today and put in good ol` Shell Rotella 15w-40. Truck is 2000 F350 4x4 dually with 147,000mi.
Question:
Did I do any harm to my motor?
What else should I do? If anything.
Thanks, Kevin
Old Jan 21, 2010 | 04:17 PM
PwerStroke99's Avatar
PwerStroke99
No it shouldnt have hurt anything, u should be fine
Old Jan 21, 2010 | 04:18 PM
DieselCamper01's Avatar
DieselCamper01
I would say you are fine also for that few miles.
Old Jan 21, 2010 | 04:42 PM
onelionhunter's Avatar
onelionhunter
Fine
For that few of miles, I am sure you will be fine as well.
I have a friend here that was adding 10w30 car oil to his for over a year and not changing it as he had a bad leak, it kept on running........... Has 230k on it now and is happily not leaking on 15-40 rotella now.
Old Jan 21, 2010 | 04:48 PM
farmdad's Avatar
farmdad
Won't be a problem as long as you didn't work the engine for a long period of time, ie. towing a heavy load, which could put contaminates into the oil. You could say that you were doing an engine oil flush since you didn't have the oil in very long. You're good to go.
Old Jan 21, 2010 | 06:29 PM
F350-6's Avatar
F350-6
The only problem might be there's still a couple quarts of the old stuff floating around in there. If she's not towing heavy or really working the engine, she probably won't ever notice a thing. If she does notice anything unusual, just change the oil again.
The only thing this is going to cost you is oil, no harm to the engine.
Old Jan 21, 2010 | 06:37 PM
Nick 99's Avatar
Nick 99
Just change the oil and filter and you should be good to go!
Nick
Old Jan 21, 2010 | 06:41 PM
Layson's Avatar
Layson
doesn't it say in the manual that you can run 10-30 in certain temperatures?
Old Jan 21, 2010 | 06:43 PM
F350-6's Avatar
F350-6
Yes, but that's assuming it's a diesel rated oil. Gas motors don't have an HPOP that will shear and foam the oil, so there are certain additives missing.
Old Jan 21, 2010 | 07:34 PM
drillerdan's Avatar
drillerdan
I don't think that's a prob. at all. I know someone who has always used plain old 10W-30 in his diesel truck and I used to do it too w/out any issues.
Old Jan 21, 2010 | 07:57 PM
CSIPSD's Avatar
CSIPSD
30wt... not 10-30... and it still has to be diesel rated.
Iowa F-150
Oil & Lubrication
Feb 20, 2011 10:25 AM
Iowa F-150
2004 - 2008 F150
Feb 13, 2011 08:55 AM
Gage2502
Jun 10, 2008 11:36 PM
Ed
Oil & Lubrication
Apr 2, 2007 10:50 AM
rusty9
Oil & Lubrication
Dec 1, 2003 10:35 PM
