FE motor mounts
Old Nov 16, 1999 | 04:45 PM
Mark Smyth
Guest
Posts: n/a
FE motor mounts
This is slightly embarassing. I just finished rebuilding my 390 for a F250 4x4 and I don't remember the up and down on the motor mounts. One side of the mount has steel wrapped around,..the other is exposed rubber. Help???
Old Nov 16, 1999 | 06:35 PM
StockMan's Avatar
StockMan
FE motor mounts
Mark:
Look at each mount. There will be a stud and small "rivet" head protruding about an inch away. That rivet head is used as a locating pin. Looking at the mount with the stud facing you, install the mount with that rivet head at the top of the mount. You will note that the frame perches are eliptical. Bigger hole on the top than the bottom. With the mounts installed on the engine, and the engine installed on the perches, these studs will sit at the bottom of these eliptical holes, the rivet head will just fit inside the eliptical hole at the top. I hope this helps
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Nov 17, 1999 | 12:37 AM
Greaseball's Avatar
Greaseball
FE motor mounts
