I deleted the factory fuel pump (HFCM) when I installed my AirDog II 130/75. Does anyone know if you can buy the upper small bowl filter separately?? If so where? Thanks
2004 Excursion, EB 6.0L
195,000 miles
MBRP turbo back lost cat
AFE Stage II intake
SCT X3 w/ Spartan Tunes
Old Edge 1000 for EGT and Boost readings,
EGR Delete RCD before the $$ was lowered.
Head Studs and gaskets
AirDog II 130/75
18" Eagles w/ Michelin tires
To my knowledge they are a package deal. It's what I have to do. If you find a place that sells the secondary filter seperately let me know.
I can get you WIX individual filters both top and bottom. Let me know.
sorry, but I would not recomend using wix, or any other "Will Fit" filters for that matter. After Market ones are know to cause problems with these trucks. MotorCraft, international, or racor only.
195,000 miles
AFE Stage II intake
AirDog II 130/75
Was your original from day one pump still working?
Other than the future upgrade potential of the AD II, the main reason for removal was that I was dang tired of the filter cap R&R during oil changes. I don;t know about others but original HFCM location on my 04 Excursion 4x4 was a pain in the a...
I gave up on that fight and just drop the front of the front drive shaft down
