no charge
Old Jan 20, 2010 | 05:55 PM
tow pro 570's Avatar
tow pro 570
no charge
Ok Dave temp light on truck cold gauge goes up as truck gets warm and battery light on from time key is turned on and gauge show no charge i did put new alternator on still nothing HELP
Old Jan 20, 2010 | 06:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
For the temp sender locations.
There are some alternator wiring diagrams listed in this link, which alternator did you install?
http://fordfuelinjection.com/?p=63
Old Jan 20, 2010 | 06:30 PM
starmilt's Avatar
starmilt
Tow pro start your own thread and you will get more responce, also tell us what you are working own as all charging syastems are not equal.
Old Jan 20, 2010 | 06:38 PM
tow pro 570
i could not start my own thred i did not have enough post so if need be it can be moved
the truck is a 1992 ford f super duty 7.3 idi alt i put on is a 130 amp internal regulator power wire to screw on back 3 wire clip and a signal 1 wire connector and the temp light is on and the gauge goes up as truck runs
Old Jan 20, 2010 | 07:02 PM
starmilt's Avatar
starmilt
Ok I see that I cant move it but will start one for you. you can tell the specifics and hopefully get some help.
Old Jan 20, 2010 | 07:07 PM
starmilt's Avatar
starmilt
no charge
Tow pro has installed a new alt and his battery light is still on on his 93 with a 130 amp alt and internal reg.
He needs some help from you guys with experience with these alt's and can't start his own thread yet.
Old Jan 20, 2010 | 08:36 PM
Dave Sponaugle
Ok here is the wiring diagram for the 130 amp internal regulator alternator from the fordfuelinjection link above.
So looking at that, the wire for the I terminal must be loose at the alternator.
Do you have an amp gauge or a volt meter in the dash?
Old Jan 20, 2010 | 08:45 PM
tow pro 570
volts but not sure
Old Jan 20, 2010 | 09:25 PM
Dave Sponaugle
How many volts is the gauge showing when the engine is running?
Try unplugging the wire on the temp switch for the light and see if the temp light goes out.
Old Jan 20, 2010 | 09:48 PM
tow pro 570
volt gauge isn't showing not a thing
Old Jan 20, 2010 | 09:50 PM
Dave Sponaugle
That sounds lie a broken wire under the dash or a dead gauge.
Will the engine start and run?
Old Jan 20, 2010 | 09:56 PM
tow pro 570
yep it starts had to put a charger on it a couple of times but it starts now on its own and GLOW PLUGS work
(how could a wire brake under dash wasn't under dash changed eng )
Old Jan 20, 2010 | 10:02 PM
Dave Sponaugle
Not sure where Ford tied the volt meter into the power circuits at.
For a volt meter, you can supply power from the ignition switch, no need to run clear out to the alternator.
Old Jan 20, 2010 | 10:07 PM
tow pro 570
i don't know but i think you put me in the right direction going to work on it tomorrow going to check out put at alt i got another temp sending unit so we will see
Old Jan 20, 2010 | 10:12 PM
Dave Sponaugle
Knowing Ford, I bet there is a wire out near the starter solenoid that I am going to say will be light green and red, that is not making a connection.
And that wire could even be at the alternator connections, and should be on the I terminal looking at the drawing.
On the external regulators, it hooks to the I terminal of the regulator.
