pulled codes, need help
Old Jan 19, 2010 | 03:39 PM
beaners1's Avatar
beaners1
I pulled the codes on my 88 with a 5.8. The codes are 33- EGR valve opening not detected and 96- fuel pump secondary circuit failure EEC didn't detect battery voltage on the fuel pump monitor circuit. The first one I can figure out its the second code I don't understand. What is the fuel pump monitor circuit.
Old Jan 19, 2010 | 06:36 PM
rla2005's Avatar
rla2005
Here is a thread from a few years back with a similar problem as yours: https://www.ford-trucks.com/forums/6...code-95-a.html
Old Jan 19, 2010 | 09:16 PM
EPNCSU2006's Avatar
EPNCSU2006
The computer monitors the output of the fuel pump relay. Code 96 comes up if the computer doesn't see 12V on this wire. This can be due to a fuel pump problem, a relay problem, or it could be something as simple as switching tanks while the engine is running. If you aren't having any problems with the fuel pumps running, I wouldn't worry about it.
