6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Auto air temp off?
Old Jan 19, 2010 | 01:23 PM
sv250's Avatar
sv250
Auto air temp off?
My new 2010's a/c is acting weird. The a/c will be on on the pass. side and the heat on the drivers side even though the drivers side is set at 65 and the pass. at 70. Actual temp was probably around 70-75. Can this be adjusted, or is it screwed? I hate to leave it at the dealer all day if I can adjust it myself.
Old Jan 19, 2010 | 02:54 PM
OBX Powerstroke's Avatar
OBX Powerstroke
I have the same issue as you and have not been to the dealer yet. When I have the temp. set at 70 for both sides, the drivers side blows cool/cold air and the passengers side hot air even though it's set on dual, not individual control. I am comfortable but the passenger is always hot unless I lower the temp. and than I freeze.
Old Jan 19, 2010 | 03:21 PM
peefrog's Avatar
peefrog
Mine does the same thing. Driver is comfortable, but passenger side blows hot. Doesn't matter if on dual or individual control. Only way to make pass blow cold is to drop to 60 on setting...waiting on a few more punch list items to take back to dealer....
Old Jan 19, 2010 | 06:11 PM
sv250's Avatar
sv250
Well at least I'm not alone. I was going to wait a bit also beffore going to the dealer to see if any other bugs come up. Its only a few weeks old. I'm hoping one of the Ford techs will pop in and shed some light on this.
Old Jan 22, 2010 | 02:13 PM
peefrog's Avatar
peefrog
just spoke w/ a buddy that has a 450, his driver side was blowing hot, opposite of us...he said they had to do a dash off to fix it, $1000 later... cause he was out of the 36000 mile warranty, so make sure to address it before the 3/36 is out...didn't get to ask what part was changed but just a heads up...
Old Jan 26, 2010 | 06:54 PM
sv250's Avatar
sv250
Brought it in today. Had to get some bedliner overspray off. This a/c deal baffeled my service writer. Says they will get into it tomorrow. It didnt do it all day there. On my way home it started again and I made a fast u turn and got the service writer to ride with me. Apparently the engine needs to be warm for this to happen. I'll keep you guys posted.
Old Jan 29, 2010 | 10:25 PM
sv250's Avatar
sv250
3 days at the dealer and theyre stumped. This is starting to pi$$ me off.
Old Jan 29, 2010 | 11:09 PM
FireMe's Avatar
FireMe
For vehicles built before 11-06-08 there is a TSB for the concern that involves inspection and replacement of the blend door actuators.
No help on the newer vehicles.
Old Jan 30, 2010 | 02:24 AM
71stang99's Avatar
71stang99
Temporarily Deactivated
what about the recirculate button, I have never owned a vehicle that would switch to outside air after I pushed the recirculate button. I hit the button, a few minutes later we enjoy the foul air from the other vehicles, why?
Old Jan 30, 2010 | 05:27 AM
senix's Avatar
senix
If you have the EATC and push off and defrost together then quickly push the auto button and it should run thru the dianostics on the the EATC.
Here should be the results:
EATC System self test error code list
024 Fault in blend door calibration during self test
025 Intermittent fault in blend door calibration
030 Self test indicates automatic temperature control sensor shorted
031 Self test indicates automatic temperature control sensor open
040 Self test indicates ambient sensor short
041 Self test indicates ambient sensor open
042 Ambient sensor intermittent short
043 Ambient sensor intermittent open
050 Self test indicates sunload sensor short
052 Sunload sensor intermittent short
115 Intermittent engine coolant temperature signal
125 Intermittent vehicle speed signal
888 End of test
Credit belongs to Koboss1.
Old Jan 30, 2010 | 03:05 PM
sv250's Avatar
sv250
Well I hope they did that.^^^^ Day 4 now. I need my truck. Mon I'm going get it or they can put me in a loaner.
Old Feb 1, 2010 | 08:33 PM
sv250's Avatar
sv250
Got it back today. They changed the control head and its doing the same thing. They said Ford tech line tells them that this is normal? I drove two other trucks on the lot and they both did the same thing. Bad design? This sucks. My wife has a Yukon with auto a/c and there are no issues.
Old Feb 2, 2010 | 08:03 AM
dm2059's Avatar
dm2059
If possible can you post this TSB or tell me where I can read about it? Thanks
Old Mar 12, 2010 | 04:12 PM
sv250's Avatar
sv250
Ok after being told this was normal, it got worse. I couldnt select the lower vents. They changed the damper and that didnt work. Finally they changeds the control head and now no more problems.
Old Mar 13, 2010 | 09:40 AM
DesertRider's Avatar
DesertRider
I also had this problem. The dealer replaced the control head, which did not fix the problem. I took it back and they said they found a TSB that said it was normal if the left and right vents were up to 15 degrees different. (mine was over 25 degrees off) It also said to replace the right actuator motor assy. They did replace the actuator and the problem was fixed. Both sides blowing the same temp now. The TSB is 09-12-15
