Block ID - can someone help?
Old Nov 9, 1999 | 01:52 PM
jowilker's Avatar
jowilker
Old Nov 19, 1999 | 02:22 PM
smokey's Avatar
smokey
After removing the oil pan, located this stamped into the block...
D1AE/AA
Does this identify the block, or am I looking in the wrong place?
Supposedly, it's a 400
thanks
Old Nov 19, 1999 | 08:32 PM
mk's Avatar
mk
The number that you found is a casting number. It doesn't identify the cid of the block but indicates the year(roughly) of the engine. I say roughly because they used the same casting sometimes for a couple of years with minor upgrades when needed. Your number indicates a 1971 casting(D=70's,1=71,A=Ford fullsize car line; a T in this position would mean it was a truck engine). Since the 400 wasn't introduced until '77, and it is a car engine, if your heads look like the 351M/400 heads it may be a 351 Cleveland. If your valve covers bolt half on the head and half on the intake manifold and it has a '352' cast into the front face of the block, it's a 360/390. mike
Old Nov 26, 1999 | 11:29 PM
mk's Avatar
mk
Looks like I made a boo-boo. The 4oo WAS available in 71,according to my Chilton book. It wasn't available in trucks, however until 77. mike
