12V wire
Old Jan 18, 2010 | 08:51 PM
smokersteve's Avatar
smokersteve
12V wire
I am installing a fuel psi gauge. What 12V wire can I tap into that will turn on and off with the key?
Thanks
Old Jan 19, 2010 | 10:12 AM
smokersteve
Does any body know of a wire under the steering wheel that has 12V and turns off and on with the key?
Thanks
Old Jan 19, 2010 | 10:24 AM
jdadamsjr's Avatar
jdadamsjr
Sorry, I don't but you have a pencil type circuit tester ?
I would get under the dash and test at the fuse box to find your wire....
consider the light circuit first for a gauge so you can control the brightness...
also consider loads for the fuse to not overload it...
brickie's Avatar
brickie
When the sun comes up I will have a look.IIRC it is orange with a pink trace.
Old Jan 19, 2010 | 10:51 AM
smokersteve
Thank you very much for the help
Old Jan 19, 2010 | 12:27 PM
brickie's Avatar
brickie
The dash dimmer wire is to the right of the steering colum in a 8 pin connector and it is the yellow wire.The power with key on is orange and tucked up behind the fuse panel it is a pass through in a bundle of orange with trace colors all of these will have power.
Old Jan 19, 2010 | 04:45 PM
smokersteve
Thanks
Old Jan 19, 2010 | 06:05 PM
smokersteve
I am seeing different color wires to tap into.
I see where these wires are but they are different colors...
3-Gauge Install Pictures
This is my truck (06 F-350)
Old Jan 19, 2010 | 10:38 PM
brickie's Avatar
brickie
Got ya. Back in a minute,I'll have a look at mine....Top second to the left on the grey connector,looks solid blue on yours.The hot is tucked away under the fuse panel to the left of that connector.
Old Jan 20, 2010 | 11:13 AM
smokersteve
Thank you so much for the help. I have seen the big fat red wire on the left of the fuse panel. When I get home I will get my tester out and hopefuly see the numbers I wana see!
