Brake Lights stuck on - help
Old Jan 18, 2010 | 02:42 PM
jmbomb's Avatar
jmbomb
I went outside today and the brake lights of my ford ranger are on. It hasn't been driven for two days, I've disconnected everything and the lights are still on. Both exterier rear lights and the third light at the back of the cab, any ideas?
I've had a lot of problems with this truck!!!
Old Jan 19, 2010 | 07:41 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Might be helpful to know the year, model & how it's equipped.
Raise the hood & try disconnecting the brake lamp lead on the brake master cylinder & tell us what happens.
Old Jan 19, 2010 | 10:41 AM
Hank85713's Avatar
Hank85713
On the pedal arm there is a switch that probably has gone south. should have 2 wires to it. disconnect and probably have to go to the dealer to get a replacement.
Old Jan 19, 2010 | 03:24 PM
wtroger's Avatar
wtroger
Ditto on the switch on the pedal. Should be able to buy it at any decent parts house
Borg Warner stop light switch S37027
Old Jan 19, 2010 | 05:39 PM
jmbomb's Avatar
jmbomb
Think it was a short in the trailor plug, found this out after I did all of the things you suggested.
2002 Ranger 4 x 4 - I bought it used and it has a lot of after market add ons that seem to be causing a lot of electrical problems.
Thanks for all suggestions
Old Jan 19, 2010 | 05:50 PM
pawpaw's Avatar
pawpaw
OK, good feedback & to hear you found the problem.
Yup, over the years I've read of numerous cases in which non OEM trailer harnesses have caused all sorts of electrical problems.
expydaddy
Jul 7, 2012 11:39 AM
tommyl
Oct 30, 2010 05:21 PM
dmccu00
Jun 18, 2002 12:00 PM
coop90
Jan 7, 2002 09:50 AM
