Oil pressure
Old Nov 19, 1999 | 11:50 AM
Joe's Avatar
Joe
Oil pressure
I have a 78 F-150 with a 302, When I start my truck the oil pressure reads about 40psi when idling. But when the truck warms up the gauge drops to about 10-15psi when idling. Is this normal??
Thanks
Joe
Old Nov 19, 1999 | 12:12 PM
390fe's Avatar
390fe
Oil pressure
This is normal for an older, high mileage engine.
Old Nov 19, 1999 | 08:28 PM
Big Red Ford
Guest
Posts: n/a
Oil pressure
From my experience with my newly rebuilt 460 and the loss of oil pressure that I experienced when engine got warm was found out to be in the main bearings. I had too much clearance... (mine was due to machine shop errors). But from that experience, and if you have lots of miles on your engine... your main bearings might be getting worn out... hence, more clearance for you to lose pressure at. Good luck.
Old Dec 5, 1999 | 08:31 AM
Trail_Rider's Avatar
Trail_Rider
Oil pressure
Old Dec 5, 1999 | 06:12 PM
Kyle's Avatar
Kyle
Oil pressure
You must also remember that the oil "thins" as it gets warmer. some resultant pressure loss is to be expected.
