LIFT AND RIDE HEIGHT LAWS IN U.S.A
#47
#49
#50
I live in Virginia, and I've never seen this one done on a truck. I do see trucks with body lifts installed and they leave the bumper in the stock location because most kits don't come with brackets to raise the rear bumper. Now I used to see lifted trucks with drop (towing) bumpers on the rear to make up for the lift, and in that situation, because it's not a factory bumper, they will measure from the frame.
#51
Big_Red_Brute,
It was a common practice until VA changed the laws. At one time the law did not cover "stock" or "aftermarket" bumpers and/or brackets. You could buy drop brackets for the bumpers and even get custom valance panels to "fill in" the resulting gap, thus keeping a more "stock" look. Of course the laws now cover this issue and that "loop hole" has been closed for years.
#52
Big_Red_Brute,
#53
Bumper drop kits are still available at the local 4x4 shops, they just won't get you around the law anymore. Beauty is in the eye of the beholder. I think a F250 dually slammed to the ground is ugly, but others love the look. I personally believe the fore-mentioned bumper headlights is a horrible idea, but someone might like it. The law was not there and the kits were being used. Va changed the law and now the kits are not used, but still available. Discredits the "out of business" theory.
PS: I should also clarify that it was common practice where I live In VA. It was kind of a convenience item also. If you ended up 1-2 inches over, after all was said and done, you could just lower the bumper a couple of inches. It seems some folks lift a truck without taking the added height of the tires into consideration. Or plan to use 38s and end up with 40s, for what ever reason.
#54
#55
The location is correct, I live in Franklin county VA. I can't say I even know anyone who has actually been charged with a height related ticket. I am sure it may be a bigger issue in some of the other cities around VA, but out here it is just the normal. I have yet to lift a truck myself, other than using slightly larger tires. I run a 235 series on my Cherokee instead of the 215 series it should have, only a few inches difference there. I don't really get into four wheeling, which I would assume is the main reason for lifting a truck. Also, it may not be a moving violation but 5-6 improper equipment tickets will still add up pretty quick. I am sure that the owner of extreme 4x4 can confirm that dropping the bumpers was a common practice until VA changed the laws. If I am not mistaken the law was changed years ago, probably 15 years ago. But I do know it was done at one time. It would not much surprise me if you have not seen any trucks that the bumpers have been lowered, I have not seen it done in a very long time. I would again assume it is because it is no longer a way of getting around the laws.
#56
hey man , not any luck yet, i dont like the set up with the lowered lights , I just figured a way around everything ,
I am registering my truck in another state, Online only . that way i don't have to smog it, and i dont neeed to modify the set up , < smart huh >
ah ha
well i need to go for now , ttul
jayson
California
#57
First to Roanoker494- I never got around to calling Xtreme today to find out about the brackets. As far as lifting a truck for 4-wheeling, while that may be some people reasoning, it's not mine. I'm lifting my truck for show purposes only. I've never been big into the offroad thing, except things like ATV's or dirt bikes. I can't imagine spending thousands of dollars building a rig to just take it out in the backwoods and trash it. But if that's what you like, then hey, I won't complain.
Now to Big-old-460- I don't blame you for not liking the idea of relocating the headlights to the bumper. I would like to know how your going about registering your truck in another state. I wasn't aware you could do that unless you lived or owned property in the state your registering it in. You might also want to make sure the state your registering it in doesn't have rediculously high vehicle taxes as some states do.
#58
#59
Canada U.S. lift laws
I didn't read the whole thread but I thought this was important. It seems there is an effort to standardize lift laws throughout N. America.
canada wide lift laws
Better to get informed and start writing and hopefully have sane laws. One of the proposals is tires limited to 35".
Richard
Richard
#60
Richard
Richard
Awww America the land of the free! Is there anything that's not regulated?
