Stalls while slowing
Old Jan 17, 2010 | 07:36 AM
Holtian's Avatar
Holtian
Hi there,
My 1990 F150 seems to have an intermittent stalling issue. I think it may be related to the vacuum system, but I haven found anything wrong with it yet.
Yesterday, I drove it about fifteen miles and was slowing from about 60 mph to make a turn when the engine stalled. It was a little hairy because I lost both the boost for the brakes and power steering! It started right up, and I drove another three miles, and it stalled once more...same thing, as I slowed down. Any ideas what could be causing this?
If it is the vacuum system I have tried checking it using a hose and funnel like a stethoscope, listening for a hissing noise. I also tried spray carb cleaner around on the hoses and valve at the brake booster to see if the engine sound changed. Nothing found, yet. I have also inspected the hoses visually. Are there other ways to check the vacuum system?
Any thoughts about what I can do to alleviate this stalling would be appreciated.
Thanks,
Randy Olson
Ithaca, NY
1990 Ford F150
5.0 liter V8, 5-speed
Old Jan 17, 2010 | 01:30 PM
Lazy K's Avatar
Lazy K
Carb cleaner is as good a way as any to find a vacuum leak. however check the PCV system and any vacuum canister. Might also have a look at the Idle Air Control valve to see if it is carboned up.
