flathead alt conversion belt help
Old Jan 16, 2010 | 07:56 PM
norvillebob's Avatar
norvillebob
I'm having trouble finding a replacement belt for my 239 flatty. I found a replacement belt but I need one about 2" min. Where are you getting you belts? I have the real fat ones.
Old Jan 16, 2010 | 09:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What do you mean, 2" shorter?
When you run wide belts, I think (not sure) you don't get any choice. Stock or nothing is my understanding. Could be wrong tho.
Old Jan 16, 2010 | 09:42 PM
52 Merc's Avatar
52 Merc
Not meaning to hijack here, but where does one find a wide groove pulley to fit an alternator? Just curious.
Old Jan 16, 2010 | 09:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Believe it or not, the stock flathead generator pulley fits a GM alternator. But they are making wide pulleys just for the alternator conversion kits.
Old Jan 17, 2010 | 05:14 AM
norvillebob
correct. on both accounts.
What I'm saying is my alt belt no longer fits the engine it's to small by a lot. I'll have to triple check how it's mounted again. Could the alt be upside down? I';ll check the folks who manufactured the bracket/ Lastly I just realized I may be able to cut down the bracket to give me more movement.
bob
Old Jan 17, 2010 | 08:04 AM
pjhjah's Avatar
pjhjah
I just went through this. Alternator on 8ba wide belt truck pumps. NAPA #'s 5L360 and 5L560. You can get belts in one inch increments from NAPA.
Pete
Old Jan 17, 2010 | 09:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Good info Pete!
Bob, the alternator should be in the same location as the generator was, and with the same size pulley, I would expect the stock belt to work. Got a pic of the setup? I assume it's the slingshot style?
Old Jan 17, 2010 | 11:03 AM
norvillebob
Pete
Pete thanks for the #'s
Old Jan 17, 2010 | 11:06 AM
norvillebob
Good info Pete!
Bob, the alternator should be in the same location as the generator was, and with the same size pulley, I would expect the stock belt to work. Got a pic of the setup? I assume it's the sligshot style?
Ross, I'll post up later if I can. (honey-do projects) It is a slingshot style is that yours in the pick may I ask the dimensions of it ? at least the bottom section.
Old Jan 17, 2010 | 11:10 AM
norvillebob
I'm starting to think I have the alt upside down? this pic was taken from the passengers side.
Old Jan 17, 2010 | 12:47 PM
norvillebob
nope either way alt measure the same distance. does any one have a measurement on a factory belt? I may have an undersized belt on here. Maybe PO used a different bracket and belt??
36" and 56" listed on napa
The outside measurement of my alt belt is 54 1/4" That may be the issue...
Old Jan 17, 2010 | 02:24 PM
petey shoes's Avatar
petey shoes
you can use a fabric tape to get you number. run tape around all pulleys. as a wide belt should never bottom out on pulleys, don't pull tape tight. just snug in center of pulleys. if adjustment is at lowest point, add 1 inch to number and this should work.
Old Jan 17, 2010 | 02:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The 36" is for the L6. Gates lists the stock belt length as 55.5" outside length, 55" effective length. The belt shown in my picture above is a 53.5", so the alt must mount a little lower. Not entirely sure if that is a wide belt or narrow, tho.
What kind of alternator is that?
Old Jan 17, 2010 | 03:12 PM
norvillebob
delco 78amp it's marked "good" so it must be
it looks like I have a little more room but the bracket is bottoming out on the engine. As a last resort I could lop off the bottom of the bracket???
bob
Old Jan 17, 2010 | 05:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is it hitting the timing cover? Honestly, I'd just get a longer belt. If you mount the alt low, it may just mean you need to buy a shorter fan belt, and you go thru the whole mess again.
