Is This Common....
Old Jan 16, 2010 | 07:43 PM
Sarge261's Avatar
Sarge261
Is This Common....
Hey all,
I was working on a customers 99 Ranger Sport 4x4 and found both the rear spring shackles were broken. I called my local Ford dealer and they told me the only way to get the shackles is to buy the springs...
Can I just buy the shackles and hardware or do I have to buy the springs too?
If I can only buy the springs to get shackles is there a good set with an extra leaf or 2, not looking to lift looking for a little extra load capability, its got a cap and he carries his tools in the back all the time.
Thanks for the help..
Sarge
Old Jan 16, 2010 | 08:04 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
It happened on my 93 S/C at over 100K. I put on a junk yard shackle and had no further problems.
Old Jan 16, 2010 | 09:10 PM
Pollack Pete's Avatar
Pollack Pete
NAPA has the shackles and the shackle to frame brackets.Right around one hundred bucks for every thing.
Old Jan 16, 2010 | 09:15 PM
Rags's Avatar
Rags
I got my hangers & Brackets ( Front & Rear of the springs, both sides ) even new bolts for everything from my local ford dealer all for about $150. I think your dealer is trying to make a BIG sale.
Old Jan 17, 2010 | 06:26 AM
powersmoked's Avatar
powersmoked
this is a common issue with these trucks. You do not have to replace the the leafsrping just the hanger and shackles.I just did my truck a 2wd a few months ago. I am pretty sure you could use the same part. Dorman 722-010 Dorman 722-010. But make sure you check. Rockauto has them for about $35 as a kit. so about $70 plus shipping.
there is a lot of threads about replacing them. I would recomend removing the bed if you can. Ths will make the whole process easier. if you have any questions feel free to ask.
if it is just the shackles they are about $20 each at rockauto. you prob could keep the bed on if it is just the shackles and not the hangers also.
Old Jan 17, 2010 | 05:29 PM
Sarge261's Avatar
Sarge261
Just need the shackles,
The hangers are good, I can get to the with the truck on the lift fairly easily so I will not remove the bed. Thanks for the Dorman part numbers I will give them to my car quest guy and see if he can order them.
Sarge
wreckinball
42
Apr 9, 2013 09:45 AM
MtnGoat
May 1, 2011 08:18 PM
kellar
Offroad & 4x4
Sep 17, 2007 06:26 AM
mnstang
May 26, 2004 12:12 PM
