Hey yall, ain't been on here in a little while finally slowing down now that the holidays are over. I installed my Baja eliminator pre-runner yesterday along with the hella 8" driving lamps. I want to hook them up so that they are on whenever my high beams are on. I'm having trouble finding which wire to splice in to. Anyways i know yall will be able to help. Also if anyone has a link for the fog light mod that would be cool. I'm gonna post some picks this evening of the light bar. Thanks again.
BB85 - Dont know for sure which wire, but you could pull one of the headlites and use a testlamp to find which terminal is hot when you turn on the high beams. If nothing else heres a bump to top. Good Luck
makes sense guess i didn't think of that. That would work great b/c the relay for my driving lights is right behind the drivers side headlight. Thanks guitarpicr
don't quote me on this one..... but. I believe there is a light blue wire under your steering column that is your high beem wire. I can look tomorrow on mine if you haven't gotten it figured out yet !
If you are using the facotry headlight switch to turn them on, then there is another way to mod this without pulling the fuse panel. Pull the dash trim on the drivers side away a little, (It just snaps on and off), then reach behind the headlight switch and release the spring loaded clips that hold it to the dash. Now you can snap the dash back in place and the headlight switch is hanging loose. Just attach a jumper wire from the brown to the White w/ black wire. Snap the switch back in place and done. VERIFY the white with black wire tho. I am positive it is the brown and about 90% sure it is the white w/black stripe.
Are we talking about 2 diffrent things in this thread?
One instruction seems to be for the stock fog lights and the other seems to be for the added on driving lights?
I want to ad some driving lights on my bumper and hook them to my high beams?
I was told I should use a relay somewhere or I might burn out my whole headlight wiring harness?
So some help with adding lights would be appreciated.
Ken........ Definatly need to use a relay for doing that. Use the highbeam wire to activate your relay ! Another words.. Take a hot wire directly from your battery to your relay, then wire your driving lights to your realay.. and use your highbeam wire only for the activation ! Clear as mud ??? I have 4 lightforce lights on the front bumper. Each pair of light has its own relay !
Ahhhh. Ok. My bad. I was thinking you were adding aftermarket lights but using the factory fog light wiring.
Sorry
I put small aftermarket lights in place of the factory fog lights ... my factory lights broke and they didn't fit well with my front receiver in the way anyways ! I use factory wiring and they work fine. I believe there is a relay already in the factory wiring for your fog lights !
I wanted Lightforce but I didnt want to sell my house to buy them , so i got some Ebay ones that seem pretty decent.
I understand that man. I was gonna do 4 lightforces in bumper and 4 behind the grill then I realized that I could buy a H2E for damn near that price haha..
