Ehaust temp gauge
Old Jan 16, 2010 | 10:13 AM
MUSTANGNICK's Avatar
MUSTANGNICK
Ehaust temp gauge
I am installing an exhaust temp gauge in a 05 f250 and was wondering where is a god place to hook the power,ground, light wires to.
Old Jan 16, 2010 | 10:35 AM
Zmann's Avatar
Zmann
depends on where you mount the gauge
Old Jan 16, 2010 | 11:00 AM
mhoefer's Avatar
mhoefer
Everything you need under the steering column to the left, use the pass through wires, pillar mount?
Old Jan 16, 2010 | 11:10 AM
william_04_x's Avatar
william_04_x
guys seem to like the DieselManor instructions.. Click..
for lighting, check behind the headlight switch(it pops right out)..IIRC blue/rd is on the dimmer, and brown is 12vt with lights on.. check those with a meter before you hook up..
Old Jan 16, 2010 | 02:02 PM
MUSTANGNICK
Thanks guys i am mounting it on the steering column cover.
