04-05 PCM
What Todd D is trying to say is that you should check your "Fuel Pump Driver Module" first. It is mounted on the frame rail near the spare tire. In the early years of the Gen 11 F-150's the module was mounted directly to the frame, metal to metal. This caused corrosion, especially in areas with road salt. There was a "retro-fit" kit that came with longer screws and standoff spacers that lifted the module off of the frame. Check the video below;
prginocx
10-06-2004 03:10 PM
