04-05 PCM
Old Nov 16, 2010 | 08:51 PM
514stang's Avatar
514stang
04-05 PCM
Does anyone know if the PCM on the 04-05 is interchangable. Heard there were less issues on the 05 modles, and wanted to start there rather than replacing the intake on my 04 to see if I get any power gain. guess I should elaberate 04 F150 4x4 Lariat major loss of power
Old Oct 25, 2019 | 02:30 AM
Todd D,'s Avatar
Todd D,
Change
You can but you should start at module on frame bad years for them a lot of corrosion then we as ring a hole on backside located drivers side by filter its 3X4 inches
Old Oct 25, 2019 | 10:05 AM
Rumble phish's Avatar
Rumble phish
What Todd D is trying to say is that you should check your "Fuel Pump Driver Module" first. It is mounted on the frame rail near the spare tire. In the early years of the Gen 11 F-150's the module was mounted directly to the frame, metal to metal. This caused corrosion, especially in areas with road salt. There was a "retro-fit" kit that came with longer screws and standoff spacers that lifted the module off of the frame. Check the video below;
Old Oct 25, 2019 | 10:28 AM
redfishtd's Avatar
redfishtd
very old thread 2010
ramhunter5877
2004 - 2008 F150
Aug 6, 2014 11:36 AM
otter814
2004 - 2008 F150
Mar 13, 2011 04:46 PM
jpass65
1983 - 2012 Ranger & B-Series
Jul 8, 2007 10:24 PM
prginocx
Oct 6, 2004 03:10 PM
RADIOMAN
Modular V10 (6.8l)
Jul 7, 2003 08:59 PM
