Sponsored by: Real Truck
upfitter help...please!
Old Jan 15, 2010 | 09:40 PM
fitman's Avatar
fitman
just puchased a 2010 f250. have the upfitter switches option/feature. where is the relay box for the switches located? says in the owners manual...."on the drivers side end of the instrument panel" i must be blind..cant find it?? any help would be greatly appreciated
Old Jan 16, 2010 | 01:49 PM
Furian's Avatar
Furian
You Keep What You Kill
Check out these links...
https://www.fleet.ford.com/truckbbas/non-html/Q157.pdf
https://www.fleet.ford.com/truckbbas...tml/Q117R1.pdf
Old Jan 16, 2010 | 10:17 PM
fitman's Avatar
fitman
thanks but still no help. i have a 2010...no removable panel below steering wheel.
i have a 2010. no removbable panel below steering wheel.
Old Jan 17, 2010 | 05:33 AM
senix's Avatar
senix
actually is does remove. Can you see the seams on the panel directly below the steering wheel?
For me I grab the very bottom on one corner and pull. Kinda scary because it is mounted with tabs at all four corners.
