04 Throttle butterfly question
Old Jan 15, 2010 | 09:23 PM
rickatic's Avatar
rickatic
I am installing an 06 engine in my 04. My 04 has the throttle butterfly and the 06 does not. Can I eliminate the butterfly and just use the 06 elbow or do I need to swap the butterfly to the 06? I am using my 04 wiring harness. Also, is there a standard size thread for the EGT probe? I have not ordered the EGT guage yet but would like to drill and tap the manifold while I have the engine out.
Thanks,
Old Jan 15, 2010 | 10:34 PM
william_04_x's Avatar
william_04_x
the 06 elbow will work fine.. your 06 PCM won't have any programming for the butterfly, and only the earliest 03/04 flashes utilize it..
1/8th" NPT is the most common size for the EGT thermocouple..
Old Jan 15, 2010 | 10:59 PM
rickatic's Avatar
rickatic
No PCM change, I am using all my 04 wiring harness and FICM. Original engine is later style 04 with the ICP sensor on the valve cover. Current flash is 12-06 I believe.
Old Jan 15, 2010 | 11:02 PM
william_04_x
you're fine.. the butterfly is the last thing to worry about with the swap..
Old Jan 16, 2010 | 05:50 AM
hndacr's Avatar
hndacr
When I did my egr delere, I removed that plate from my 04. What if any effect did that have?
Old Jan 16, 2010 | 09:12 AM
william_04_x
the throttle body is supposed to help EGR flow when the motor's spinning slow, and decrease warm up time.. removing it doesn't really help, nor hurt..
