Does this seem odd?
Old Jan 15, 2010 | 11:41 AM
Lngbeard's Avatar
Lngbeard
Does this seem odd?
I just finished a cam swap in my 71 460. Installed Lunati 61601 for low end grunt. I was priming the oil system with a drill motor and stripped down distributor, seeing oil at the rockers, all good. Wanted to see if I had oil pressure showing on the guage. Turned on key, then ran the drill motor again. When I spun the oil pump the electric fuel pump kicked in too! It filled the carb up until the floats shut off the needle and seat. Why would fuel pump run? I know fuel will shut off if low oil pressure is sensed, will it also run if good oil pressure is found? It was no problem, actually it save me from having to fill the carb manualy prior to cam break in. Just surprised to have it happen. Thoughts?
Old Jan 15, 2010 | 04:18 PM
bashby's Avatar
bashby
I'm not 100% sure how that circuit works but it sounds normal to me.W/ Key on the pump gets power through the op switch
Old Jan 15, 2010 | 04:36 PM
sctrt's Avatar
sctrt
bashby
What is the op switch.
sctrt
Old Jan 15, 2010 | 07:11 PM
Lngbeard's Avatar
Lngbeard
I thought on these systems the fuel pump did not run until the starter relay is engaged. Why would spinning oil pump start fuel flow? the key alone did not start the fuel pump.
Old Jan 15, 2010 | 07:47 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
These pumps run when the ignition is in start (with no oil pressure) and also in run when the oil pressure (OP) switch senses pressure.
Old Jan 16, 2010 | 10:06 AM
Lngbeard's Avatar
Lngbeard
That makes sense, just never seen it in action before. Made it easy to fill the carb for quick first start up on cam swap. Last time I filled the carb with a hypodermic through the float fuel level holes on my Holley. Thanks.
Bobbys Big Red Rig
23
Sep 23, 2013 07:40 AM
1960fordf350
Jul 17, 2013 03:52 PM
scratch1956
16
Mar 19, 2013 02:16 PM
GT-Rex5.0
Aug 23, 2011 08:19 PM
Sycostang67
Aug 13, 2009 11:31 AM
