F350 crew cab-front center seat/console combo
Buy the King Ranch and take out the center console. Buy a Jump seat on e-bay and have it covered in the King Ranch leather. This would be the least expensive option and the jumpseat will bolt into the exsisting holes that's already there. The issue you will have is where the console meets the dash. The 2011 trucks the front dash panel has a indention for the console. You could solve this buy purchasing a 2008-2010 dash panel as it should fit.
I just took a black cloth jumpseat out of my 2010 reg cab and installed a console. It bolted right in.
Hmmm, quite the delema. Maybe give a direct call right to ford and let them know how you want to spend all this money on a truck from them, and just maybe they might be able to help ya out. If not then maybe someone there could tell ya if the 20 jump seat would fit between the front seats and just get it upholstered. I can't see them changing the design of the seats or the dash just for the kr style, but one just doesn't know, plus I haven't stuck my head into an 11 yet to see the differences.
Thanks again for the responses, to be continued...
The interior on the 2011 is almost the exact same as a 08-2010. As far as the cab, floor, seats, dash is only slight cosmetic changes. A 08-2010 jumpseat should fit a 2011 cab, holes should also line right up. The issue will be you will have to order a new dash panel(the panel around the radio, AC and Upfitter switchs) from a 08-2010. Since the dash is the same, the 08-2010 panel will fit the new 2011 dash.
I would go look at a 2011 and compare, measure the bolt holes on the cab floor. You can order a jumpseat off e-bay for less than a couple hundred dollars and have the cloth replaced with the KR leather.
Check it out.
https://www.ford-trucks.com/forums/9...nter-seat.html
90pioneer
13
01-04-2019 01:25 AM
Bobcatskidsteer
6.4L Power Stroke Diesel
45
08-23-2006 10:27 PM
