Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
6lb pulley
Old Jan 15, 2010 | 07:19 AM
xSAILORBIBLEx's Avatar
xSAILORBIBLEx
6lb pulley
i just installed a 6lb pulley on my 02 lightning and it looked fine at first then i did a smal crank to see what happens and the 6lb pulley is rubbing the cooling fan rod. WHAT DO I DO. are there spcers for this? help please you can even call im gonna be on all day 8505321654
Old Jan 15, 2010 | 07:32 AM
xSAILORBIBLEx
i just installed a 6lb pulley on my 02 lightning and it looked fine at first then i did a smal crank to see what happens and the 6lb pulley is rubbing the cooling fan rod. WHAT DO I DO. are there spcers for this? help please you can even call im gonna be on all day 8505321654 any ideas at all
Old Mar 19, 2010 | 12:04 PM
Gearbanger 101's Avatar
Gearbanger 101
If its just the shroud, can you not file a little of the contact area on it away until it clears?
A couple of pictures would be helpful.
