Strange engine noise
Anyone ever heard this one?
kbub
On the tick, maybe something like a bad setpentine belt, with a chunk of rubber missing from the back side, maybe low oil pressure to a valve lifter, or a sticking lifter, ect.
On the squeal, maybe something like a bad bearing in any one of the belt driven accessories, or the cam sensor bearing, which is known to squeal when it's going out on the 3.0L Vulcan.
I had a cricket like chirp from an OEM idler pully bearing, with ever so slight amount of play, on my 94 Taurus 3.8L.
Maybe try using a mechanics stethoscope to further isolate the noise. If you don't have one, fashion such with a length of hose, or tubing, a wooden broom handle, or a long screw driver, one end on the suspect, the other end to your year.
Anyway try to listen & narrow down where the noise is coming from.
Some thoughts for pondering, let us know what you find.
