Sponsored by: Real Truck
6.4L Advice
Old Jan 14, 2010 | 06:57 PM
MagicMan101's Avatar
MagicMan101
6.4L Advice
Gentleman,
I am thinking of taking the plunge and actually <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_1_0>buying</NOBR> a newer vehicle.
2008 <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_2_0>F-250</NOBR> with the 6.4 with an SCT and DPF. I am unfamiliar with the 6.4L and am asking your opinions of the motor and its' dependability. In addition, it still has a 100,000 warranty which is obviously voided with
an SCT and DPF on the <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_3_0>truck</NOBR>. I am curious if any of you guys had this modification to your truck and had to take it in to the dealer for work, what did you do? If you took the mods off, can the dealer take note that you have been using a programmer and DPF? How long does it take to put the original DPF back in?
Thanks for all the help
<!-- / message -->
Old Jan 15, 2010 | 12:23 PM
Cowboy65's Avatar
Cowboy65
Welcome to FTE. I would suggest that you post your question in the 6.4L section of the forum. They also have a Tech Folder which should contain some good info. The link is below.
6.4L Power Stroke Diesel - Ford Truck Enthusiasts Forums
