06 6.0 missing please help
Old Jan 14, 2010 | 06:10 PM
Dvirg1600's Avatar
Dvirg1600
My truck seems to be missing due to a fuel problem, most of the time between 70mph and 80mph as I accelerate it jumps and jerks, if I stand on the pedal it goes away or if I let off it stops. It also does it real bad when pulling a heavy load. I have taken it to the dealership two times and they haven't found the problem. but also they don't go drive it at 80 either. Hopefully one of you gurus have seen this before. Thanks in advance
Old Jan 14, 2010 | 07:16 PM
embry1123's Avatar
embry1123
having very similar problems with my 03. Going to check the EGR this weekend.
Old Jan 14, 2010 | 08:01 PM
Dvirg1600's Avatar
Dvirg1600
seems like I remember at 40k mles with I head gasket replaced they also changed the EGR truck now has 85k, How do you test the EGR?
Old Jan 14, 2010 | 08:20 PM
embry1123's Avatar
embry1123
I'll actually be pulling mine out to clean it. From what I've been told here on the site and from what else I've read, it may be stuck which will not allow the boost to build properly.
Old Jan 14, 2010 | 08:36 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Here's a thread from the 6.0 tech folder sticky with the info you need to remove and clean your EGR valve:
https://www.ford-trucks.com/forums/4...egr-valve.html
Old Jan 14, 2010 | 08:38 PM
embry1123's Avatar
embry1123
Thanks Steve, that's awesome man!
Old Jan 14, 2010 | 09:40 PM
cheezit's Avatar
cheezit
sorry but I would not drive a customers truck faster then the posted speed limit either.
Old Jan 14, 2010 | 09:49 PM
Dvirg1600's Avatar
Dvirg1600
so what do you think cheezit? dirty EGR?
Old Jan 14, 2010 | 09:52 PM
cheezit's Avatar
cheezit
I would have to have the truck for this one. could be ipr/standpipe issues. could be injector, oil pressure issue on the hpp side like block off going bad, fuel pressure.
Old Jan 18, 2010 | 02:53 PM
Dvirg1600's Avatar
Dvirg1600
One other side note, my truck has been run with a diablo programmer for all but 10k on the 60hp setting and the other 10k it was run on 100hp boost. truck has 83k not sure if this matters just thought I would add the info
Old Jan 18, 2010 | 02:59 PM
SteveBricks
FTE Emeritus
It might matter...I'd take it off and see if anything changes before tearing into the motor.
Old Jan 18, 2010 | 05:21 PM
Dvirg1600's Avatar
Dvirg1600
I have tried that before and it still did it with the programmer out, UPDATE: I pulled the EGR and it was nastier than the one in the how to picture, in some spots there was at least an eighth inch thickness of black ****, anyway I went for a spin on the hwy and I couldn't get it to act up anymore, but that doesn't mean its fixed cause somedays it doesn't act up. As of now I'm gonna hope its fixed but if acts up again I will post back thanks for the help
