pulled some codes
Old Jan 13, 2010 | 10:45 PM
nikolass's Avatar
nikolass
pulled some codes
I pulled the codes but im not sure how to read them
the first one was:
3 blinks, 2 sec stop, then 2 blinks, 4 sec stop, 3 blinks, 2 sec stop, then 1 blink
It did that same code three times before it stopped?
any help would be appreciated!
Old Jan 14, 2010 | 12:26 AM
Brigart's Avatar
Brigart
3 blinks (3)
2 second pause (digit separator)
2 blinks (2)
= code 32
4 second pause (code separator)
3 blinks (3)
pause
1 blink (1)
=CODE 31
31 =pfe,evp,evr circuit below minimum voltage
32 = EVP below closed limit
Sounds like your EGR valve position sensor (EVP) is getting you your codes.
Theres instructions to test the reference voltage and position voltage in the chiltons. Could be EGR valve but two times low codes sounds like a disconnected or bad sensor.
Good luck
Brigart
Old Jan 14, 2010 | 06:43 AM
nikolass's Avatar
nikolass
wow thanks for explaining that I was searching all over the place to see how to do that!
Old Jan 14, 2010 | 09:47 AM
Brigart's Avatar
Brigart
Here is a more detailed how to.
Ford Fuel Injection How To Run a Self-Test
