Sponsored by: Real Truck
Boost Gauge Question
Old Jan 13, 2010 | 06:18 PM
mcgyver5150's Avatar
mcgyver5150
I have a 99 F250 SD with the 7.3 and want to put in a boost gauge. Where does it connect under hood or is there a chance there is a connection port under the dash somewhere that's just capped off.
Old Jan 13, 2010 | 07:19 PM
Lubbockguy1979's Avatar
Lubbockguy1979
You can tap into the intake elbow or tap into the map sensor. I'm not sure if the obd2 port reads boost on the older trucks
Old Jan 15, 2010 | 09:59 AM
mcgyver5150
Ok, I'll look into doing it that way...thanks!
