valve cover question
Old Jan 13, 2010 | 06:01 PM
fixitman1310's Avatar
fixitman1310
hey guys i have a 96 f250 king cab. i need to replace the valve cover
gasket,glow plugs and harness . is it possible to remove the cover
without removing heater box.
thanks alot for help here
steve
Old Jan 13, 2010 | 06:15 PM
kawa's Avatar
kawa
Talking
Steve,
I have a 97 250 and found that once everything is unbolted to just lift up and kinda roll the cover clear of everything. it's difficult to explain but just experiment a little and you will get the hang of it.
Rog
Old Jan 13, 2010 | 06:16 PM
427 fordman's Avatar
427 fordman
Yeah there is a box on the side of it by the valve cover. Mine had 2 little 5/16 self tapping screws holding it on. Some say theirs is glued on. You have to peel back the insulation and you will see it. If yours is glued on I suppose you just be careful and pop it off with a small prybar.
Old Jan 13, 2010 | 06:35 PM
RRranch's Avatar
RRranch
Why are you replacing everything? Testing all those parts is easy. They sure are expensive.
Old Jan 14, 2010 | 10:56 PM
fixitman1310
my wires are bad under the valve cover. my glow plug wire smokes when
starting the engine. i think my gasket is bad, leaking oil as well.
thanx
steve
Old Jan 14, 2010 | 10:57 PM
fixitman1310
i will try and get it off without moving box. thanks for advice.
Old Jan 14, 2010 | 10:59 PM
fixitman1310
also i have a bad harness under the cover. wires burning
Old Jan 15, 2010 | 01:41 AM
Muktown's Avatar
Muktown
powerstrokeshop.com has everything in one kit. glow plugs wire harnesses and valve cover gaskets for both sides. they are all oem motorcraft parts. like others have said the parts arent cheap. i think its like 295 for everything for both sides
Old Oct 9, 2011 | 08:52 PM
Merkinman95's Avatar
Merkinman95
I did my drivers side UVCH and harness outside. They were all fried... BAD. Run good then miss real bad. Checked plugs Holy cow, shouldn't have run at all. Runs like a oil burner should...NOW
Resendiz
Oct 18, 2016 08:56 PM
tonefordays
1983 - 2012 Ranger & B-Series
Apr 12, 2016 10:02 AM
car42jam
Apr 25, 2012 04:21 PM
ltl_jrw
27
May 28, 2010 12:08 PM
bigpumpkin
Sep 17, 2002 10:06 PM
